I have a central gateway with several remote tag providers, all coming from Ignition Edge instances.
In the Ignition Edge gateway settings, I configured permissions to read tags at that gateway.
How can I, through the Java SDK presumably, access those Tag Read Permissions?
I assume it will return a PermissionsConfig object of some sort, but i'm really just looking for a way to "disable" a button in Perspective if the current user doesn't belong to that set of permissions specifically.
My alternative workaround is to use the .CanRead property on a random tag in the tag provider, but that could potentially have additional Read Permissions set, outside of the ones at the tag provider itself.
