PersistenceInterface Exceptions
Using Ignition 7.9.10 on redundant gateways. This was on the master gateway. Initial symptoms were all Vision clients were down, and webpage was inaccessible. GCU showed Gateway running, and web server started. Restarting the master gateway brought everything back up, and no issues since then. Just trying to see if I have a more fundamental problem that is going to creep up again.
I see a similar issue in this thread, but it’s suggested that 7.9.5 is the fix to this, which wouldn’t apply to this system.
I had the following errors multiple times a second while the issue was occurring:
PersistenceInterface	20Sep2021 17:49:29	Attempting to open new session, but session already open for this thread.
java.lang.Exception: null
at com.inductiveautomation.ignition.gateway.localdb.PersistenceInterfaceImpl.getSession(PersistenceInterfaceImpl.java:56)
at com.inductiveautomation.ignition.gateway.localdb.PersistenceInterfaceImpl.getSession(PersistenceInterfaceImpl.java:44)
at com.inductiveautomation.ignition.gateway.sqltags.tagproviders.internal.InternalTagStore.openIfNot(InternalTagStore.java:1303)
at com.inductiveautomation.ignition.gateway.sqltags.tagproviders.internal.InternalTagStore.internalStoreTagValues(InternalTagStore.java:1341)
at com.inductiveautomation.ignition.gateway.sqltags.tagproviders.internal.InternalTagStore.storeTagValues(InternalTagStore.java:1250)
at com.inductiveautomation.ignition.gateway.sqltags.providers.AbstractStoreBasedTagProvider.tagValuesChanged(AbstractStoreBasedTagProvider.java:2433)
at com.inductiveautomation.ignition.gateway.sqltags.scanclasses.SimpleExecutableScanClass$ScanClassTagEvaluationContext.processAndReset(SimpleExecutableScanClass.java:1141)
at com.inductiveautomation.ignition.gateway.sqltags.scanclasses.SimpleExecutableScanClass.run(SimpleExecutableScanClass.java:901)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$SelfSchedulingRunner.run(BasicExecutionEngine.java:483)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$TrackedTask.run(BasicExecutionEngine.java:565)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Config	20Sep2021 17:49:29	Error storing tag values.
simpleorm.utils.SException$Error: Transaction already committed, need begin.
at simpleorm.sessionjdbc.SSessionJdbc.checkBegunThread(SSessionJdbc.java:353)
at simpleorm.sessionjdbc.SSessionJdbc.rollback(SSessionJdbc.java:408)
at com.inductiveautomation.ignition.gateway.localdb.PersistenceInterfaceImpl.getSession(PersistenceInterfaceImpl.java:57)
That’s a bug. Pretty sure it has since been fixed.
I’ve had similar in module development due to poor object lifetime management… /: This is in an IA module.
Do you remember when it was fixed? In a 7.9.x update? Or only in Ignition 8? I’ve never had this issue in Ignition 8, but that’s obviously a bigger upgrade than just a newer 7.9 update
No, but current is v7.9.18. 7.9.10 is pretty old.
