Hello All,
Just wanted to add this here for consideration and hopefully for the benefit of others. As noted, without some trickery, getting gateway data to persist requires a slight workaround. I noted this condition also exists for the modules directory which is /usr/local/bin/ignition/user-lib/modules/
I'm testing the following configuration which expands upon the concept of using an init container that seeds initial data which kcollins1 designed. The difference here is that I'm overwriting the stock modules by default every time the pod starts. Thus, if the base image changes, the stock modules are always overwritten and refreshed to the PersistentVolume. Any 3rd party module uploaded by the user should remain intact and untouched.
Things are testing favorably thus far with the CirrusLink MQTT module, so hopefully others find this useful.
Relevant Snippets Here;
spec:
volumes:
- name: ignition-pv-mqtt-volume
persistentVolumeClaim:
claimName: ignition-pv-mqtt-claim
- name: ignition-pv-modules-volume
claimName: ignition-pv-modules-claim
initContainers:
- name: seed-volume
image: inductiveautomation/ignition:8.1.24
command:
- sh
- '-c'
if [ ! -f /data/.ignition-seed-complete ]; then
touch /data/.ignition-seed-complete ;
cp -dpR /usr/local/bin/ignition/data/* /data/ ;
fi
cp -dpR /usr/local/bin/ignition/user-lib/modules/* /modules/ ;
resources:
limits:
cpu: '1'
memory: 256Mi
requests:
cpu: '1'
memory: 256Mi
volumeMounts:
mountPath: /data
mountPath: /modules
Two PersistentVolumeClaims above, one for the gateway data and another for the modules directory.
containers:
- name: ignition
args:
- '-m'
- '4096'
- '-n'
- Ignition-MQTT-Server
ports:
- name: ignition-http
containerPort: 8088
protocol: TCP
- name: ignition-https
containerPort: 8043
protocol: TCP
env:
- name: ACCEPT_IGNITION_EULA
value: 'Y'
- name: TZ
value: America/Chicago
- name: IGNITION_EDITION
value: standard
- name: GATEWAY_MODULES_ENABLED
value: >-
allen-bradley-drivers,bacnet-driver,dnp3-driver,enterprise-administration,logix-driver,modbus-driver-v2,omron-driver,opc-ua,siemens-drivers,udp-tcp-drivers
resources:
limits:
cpu: '1'
memory: 4Gi
requests:
cpu: '1'
memory: 4Gi
volumeMounts:
mountPath: /usr/local/bin/ignition/data
mountPath: /usr/local/bin/ignition/user-lib/modules/
And, as shown above, in the primary container, the mount for /usr/local/bin/ignition/user-lib/modules.
