Perspective 8.1.3 Table Sorting when Headers are numbers
Im Looking for a way to remove all sorting on a table and display data as per the query results. Im find even if i define the columns in order it still wants to put the settings column to the far right. I need the settings column on the left. The data is parsed with external script from multiple websites and added to mysql tables.
Query Results:
Table Auto sorting for some reason:
In your columns property, are you exactly matching the case of the data's column names?
Yes
Ok i think i got it. i didnt see it was putting a , in the number
I think you are going to keep running into trouble as long as your column names can be interpreted as numbers.
Yes i think so aswell . It was a pain with mysql as the table names are the numbers i needed ``. I put a generic name infront of the number hopefully it will help . thanks for your help
