I am trying to access some output params in a view I made, where that view is used in an Embedded View (which is in a Flex container <- not sure that matters, as, I tried this with and without it). The problem I am having is that the output params don’t seem to be accessible anywhere that I can find. They do not show up in the property binding searches, nor can I seem to access them through params.{name}.
The documentation says, “the output values will appear as properties” ( from: https://docs.inductiveautomation.com/display/DOC80/Views+and+Containers+in+Perspective ), but like I said, I can’t seem to find them.
Thank you for your help ahead of time,
-Matt
