Really like the direction that the Ad Hoc Trend Version 1.0.5 is heading. Nice work.
I have a question (perhaps a bug) that I could use some help on. What I have noticed is that when using the Save function to a JSON file with a Start and End history date, and then reloading the JSON file into the Ad Hoc trend, the trend itself does not seem to display the Start/End history range in the trend.
I have checked the JSON file to see if the Start and End date/times are correct and they seem to be OK.
dateFormat “YYYY/MM/DD”
endDate "Dec 2, 2020, 11:59:00 PM"
measureOfTime “minutes”
mode “historical”
pointCount 300
rangeEndDate “Dec 2, 2020, 10:39:32 PM”
rangeSelectorPen “histprov:MSSQLExpress:/drv:ignition-vdevignition01:sample_tags:/tag:random/randomboolean2”
rangeStartDate “Dec 2, 2020, 4:08:05 PM”
refreshRate 1000
responsiveDesignWidth 750
startDate "Dec 2, 2020, 2:35:00 AM"
tagBrowserStartPath " "
timeFormat “h:mm A”
unitOfTime
Is there something that I am missing with the implementation that I need to adjust? (i.e. is the dateFormat property a potential issue (this is the default format of the object in JSON file which I have not changed). This is auto populated with the Date/time picker built into the Perspective Power Chart.
Thanks in advance for your help.
