Hello All,
I am using a popup window that has a parameter passed in to set an "Area" to filter alarms in the status table component. I have a binding on props.filters.active.conditions.source. I am seeing instances where the filter is not applied and I get the wrong alarms, or I get no alarms at all. I should mention this is a scale out architecture and the remote tag provider alarm setting is set to subscribe. I have seen some older forum posts from @nminchin regarding this same issue, and it seems the issue persists in 8.1.26. Any help is appreciated.
Regards,
Frank
