I have an alarm status table. I would like to use styles for each row type priority. As you know each row type has a base section and priorities section. I noticed I have to delete the inline properties in base section in order for the styles assigned to each priority to work , and it worked . However when I close the view and reopen it all the base properties are back and therefor the styles in priorities are not in effect anymore. Am I missing something or doing something wrong?
Noting that a working solution is described here: Alarm status table row styles flashing and static backgrounds based on priorities - #11 by angus123
