Perspective App doesn't find the Gateway automatically, and I can not manually input a Gateway host name and port for my local WiFi network. I tried to enter the IPAddress http://192.168.8.1 to connect to the Ignition Gateway. Ignition App did not find the project.
Why not? Set your gateway machine to a fixed IP address (and related settings).
192.168.8.1 seems to be the address of the router or AC, are you sure your ignition server address is 192.168.8.1?
In addition to confirming this, you'll also want to add the port to the end of the IP address (default is 8088). If using the default port and the IP is correct, then the full address to enter would be http://192.168.8.1:8088
Thanks for your response concern my problem! I tried to enter full address http://192.168.8.1:8088, but Ignition App returns that Host invalid.
Please describe your network in detail. Go to each machine and look at its IP address--include that information in your description. Do note that a network configuration's "gateway" is not an Ignition gateway.
It looks like the desktop you're running ignition on has an IP address of 192.168.8.117.
Try using this in the Perspective app instead.
Consider also trying http://desktop-sqc7tb0:8088/. Many upstream DHCP/DNS/router combo devices will inject such local device names into their local DNS, enabling a local "dynamic DNS" functionality that will allow you to not worry about changing IP addresses.
Do you need to turn the firewall off on the PC hosting the Ignition Gateway? Or do you need to add firewall exceptions for 8088 to that PC?
