Perspective Auditing
Just wanted to share a solution to how to audit/log user actions via perspective. An Ignition rep helped us out with this and I imagine some people may have a similar need/issue.
First thing was that registering perspective user login/logout does NOT work with the default audit database. You need to create your own audit table to do this, so we made a table named PERSPECTIVE_AUDIT_TABLE.
To register login/logout user events, in Designer go to Project->Session Events->Startup (or Shutdown). then you can insert code like we did:
userName = session.props.auth.user.userName
action = "Login"
system.db.runPrepUpdate("INSERT INTO PERSPECTIVE_AUDIT_TABLE(ACTOR,ACTION) VALUES (?,?)", [userName, action])
Logging user control changes such as button presses, etc. are done via component event scripting. For example for a slider action we used:
userName = self.session.props.auth.user.userName
action = self.view.params.Farm + " " + self.view.params.ControllerName+" forced on for " + str(self.getSibling("NumericEntryField").props.value) + " Minutes"
system.db.runPrepUpdate("INSERT INTO PERSPECTIVE_AUDIT_TABLE(ACTOR,ACTION) VALUES (?,?)", [userName,action])
Anyways we really appreciate the help from the Ignition team and hope this can help other people. Thanks.
This was very handy. I was looking for a good way to handle tag events, this works good. Thanks.
Note that first-party Perspective auditing landed in 8.0.8 - login, logout, and security level changes included. Also, 8.0.12 (probably) will have a system.util.audit() function available in all scopes.
Can I ask why don’t you use the perspective audit table for manually insert data and create a new table?
Nader - you’re correct as of right now. However at the time we had the need, the perpective audit table was not yet available.
Hi Paul
Is there any restriction on using system.db.runPrepUpdate("INSERT INTO audit_events …) in perspective?
Because I can insert new row in audit table with system.db.runPrepUpdate("INSERT INTO audit_events …) in vision but it seems it doesn’t work in perspective.
The reason I don’t use `system.util.audit()’ is this is npt available in 8.0.12.
Thanks for your post bro @richard.d.white
