Perspective Auto Login
Have read through forums but couldn’t find a suitable answer…
Does anyone know how I can set auto login for the perspective module? I can do it easy for vision, but not perspective.
It doesn’t have auto-login. Instead, you can set up a project that doesn’t require authentication.
Very much depends on your authentication setup… Our IdP is Office365 and my sessions all SSO login as my system/browser is already authenticated to Microsoft.
You might want to watch this thread for more details [FEATURE-1402] Perspective “autologin” IdP - Ignition - Inductive Automation Forum
Just checked it out. Thank you!
Is there a possible way to set that up as a base but then also have the login feature for higher level access?
Just add security to your views you want to secure.
https://docs.inductiveautomation.com/display/DOC81/Security+in+Perspective
I did it in my project
I created a header page, without any security on it.
I add an empty label, but you can use any component in it
Add the following in a Startup Script on this component
if not system.perspective.isAuthorized(False, ["Authenticated"]):
	system.perspective.login()
So whenever I have a page with security, I use this header
Works perfectly. I have a Map view in vision (browser module) that I use to look at the Map url and it would always ask me to login when security was enabled. I just put the script on my main header which I don’t use for this View and so I have security in rest of the project except this one!
Thanks.
