Perspective - best way to transform two or more properties (avoiding script transform)
I am using Ignition 8.1.50 with Perspective module.
I know that in transforms is better to use map/expressions rather than scripts, but I want to understand if is possible to create a logic like this without a script transform
So basically whenever one of the two properties change, the transform logic will be evaluated to produce the result.
A nested if expression should work. Expressions re-evalutate if any of the referenced items change value.
if(
	{view.params.FamilyName} = "", "none",
if(
	{view.params.Available}, "solid",
	"dashed"
If everything you are monitoring is a boolean, you can use binEnc and a case statement to make it a bit cleaner.
You can also use an outlandish form of case. it works and is less characters than nexted ifs:
case(True
	,{view.params.FamilyName} = "", "none"
	,{view.params.Available}, "solid"
	,"dashed"
@nminchin thanks this is very good
