Perspective: Bind instance parameter using scripts
Good morning.
In Ignition 8.1.15, I have written a script to build the view instances of a Flex Repeater. One of the view’s parameters is a tag value, and I’d like to bind it through the script.
If I just assign the value to the parameter, it logically doesn’t bind to the tag, and the parameter won’t change when the tag value changes.
As I have programmed the script, “tagValue” is static, I need it to be dynamic.
Best regards.
Instead of passing the value to the tagValue parameter, add an indrect tag binding on tagValue in the view.
I have created a new parameter (tagPath) in the view and bound the label to this parameter:
I have modified the script that creates the instances in the Flex Repeater, but the final result is not what I expected. Instead of displaying the value of the tag, “value” is displayed:
Script:
Flex Repeater:
Best Regards.
Use an indirect tag binding, add a script transform to add the units. My example uses a custom property called tagValue
binding on tagValue
Transform script:
	stringOut = '{} {}'.format(value, self.params.tagUnits)
	return stringOut
It works perfectly with both Expression Binding and Indirect Tag Binding.
I was editing the wrong view :frowning:
Thanks.
I wish i could say I’ve never done that. But I have. Sometimes often.
