8.1.8
I get error on binding while loading page, it appears when I use an object in expression and try to access a key throw a script. Error appear shortly but it’s agressent.
It’s hard to tell without seeing all of the pieces, but while a KeyError is definitely encountered when looking for a key “enabled”, it appears to be the “enabled” key of a “myTrigger” object, not the typeAction object you supplied a screenshot for. Could you provide insight into the myTrigger object?
I have 3 types of trigger, myTrigger is the active one and comes from type_action in that case
Transform the incoming value and return a result.
Arguments:
self: A reference to the component this binding is configured on.
value: The incoming value from the binding or the previous transform.
quality: The quality code of the incoming value.
timestamp: The timestamp of the incoming value as a java.util.Date
classes="Table/tbl-txt-center-bold Text/txt-lbl-overflow-hidden Colors/borderColor-black Text/txt-desc"
try:
if not "Alerts" in value["color_name"]:
if not self.view.params.alert_value_path is None and not self.view.params.alert_value_path=="":
my_codes = _Functions.getConstDict(self.view.custom.severity_path)
my_codes = _Functions.reverseDict(my_codes)
alert_code = my_codes[str(value["alert"])]
else:
alert_code = ""
except:
return
#MODE
if value["type"]=="mode":
if not value["text_classes"] is None:
classes += value["text_classes"]
if not alert_code=="" and value["myTrigger"]["active"] and value["alert"] > 0:
return classes + " Alerts/backgroundColor-" + alert_code + " Objects/toggle-pointer-enabled"
elif value["myTrigger"]["pending"]:
return classes + " Colors/backgroundColor-" + value["color_name"] + "Light-" + value["color_name"] + "Dark_blink Colors/color-white Objects/toggle-pointer-enabled"
elif value["myTrigger"]["active"]:
return classes + " Colors/backgroundColor-" + value["color_name"] + "Light Colors/color-white Objects/toggle-pointer-enabled" #Colors/backgroundColor-green
elif value["myTrigger"]["can_request"]:
return classes + " Colors/backgroundColor-" + value["color_name"] + "Dark Colors/color-white Objects/toggle-pointer-enabled"
else:
if not value["has_needs"]:
return classes + " Colors/backgroundColor-grayLight Colors/color-gray Objects/toggle-pointer-disabled"
return classes + " Colors/backgroundColor-grayLight Colors/color-gray Objects/toggle-pointer-enabled"
#ACTION
elif value["type"]=="action":
if (not value["myTrigger"]["enabled"] or value["myTrigger"]["enabled"] is None) and not value["myTrigger"]["started"] and not value["myTrigger"]["custom_view_exist"]:
return classes + " Colors/backgroundColor-grayLight Colors/color-gray Objects/toggle-pointer-enabled"#Colors/txt-disabled-color"# Objects/toggle-pointer-disabled"
if not value["text_classes"] is None and not value["text_classes"]=="":
std_color = value["text_classes"]
else:
std_color = "Colors/color-white"
if value["myTrigger"]["custom_view_exist"] and not value["myTrigger"]["can_start"]:
elif value["myTrigger"]["risky"] and value["myTrigger"]["enabled"] and not value["myTrigger"]["started"]:
return classes + " Colors/backgroundColor-amber " + std_color + " Objects/toggle-pointer-enabled"
elif value["myTrigger"]["started"] and not value["myTrigger"]["ended"]: #value["enabled"] and
return classes + " Colors/backgroundColor-" + value["color_name"] + "-" + value["color_name"] + "Light_blink " + std_color + " Objects/toggle-pointer-disabled"
elif value["myTrigger"]["enabled"] and value["myTrigger"]["signal"]:
return classes + " Colors/backgroundColor-" + value["color_name"] + "Light " + std_color + " Objects/toggle-pointer-disabled"
return std_color + " " + classes + " Colors/backgroundColor-" + value["color_name"] + " Objects/toggle-pointer-enabled"
#TRIGGER
elif value["type"]=="trigger":
else:
if "Alerts" in value["color_name"]:
if value["myTrigger"]["enabled"] and not value["myTrigger"]["signal"]:
return classes + " " + value["color_name"] + " " + " Objects/toggle-pointer-enabled"
return classes + " " + value["color_name"] + "_blink Objects/toggle-pointer-disabled "
return classes + " " + value["color_name"] + " " + " Objects/toggle-pointer-disabled"
else:
return classes + " Colors/backgroundColor-" + value["color_name"] + " " + std_color + " Objects/toggle-pointer-enabled"
return classes + " Colors/backgroundColor-" + value["color_name"] + "-" + value["color_name"] + "Light_blink Objects/toggle-pointer-disabled " + std_color
return value["type"]
What you’re encountering is that the binding has not resolved by the time you try to access the enabled key. You could either opt-out of the overlay in the binding dialog, or you could gracefully handle the KeyError within the script you provided:
try:
elif value["type"] == "action":
if (not value["myTrigger"]["enabled"] or ...
except KeyError:
# do something else here
Why that issue is newer in 8.1.8 ? I nerver encounter that before, and many of our pages has that issue now.
