Perspective blower/fan
Anybody has an animated blower/fan with udt, willing to share?
Or point me to one in Exchange?
I usually make a UDT based on the device model I'm working with but I have a couple blower SVGs that may be helpful. The red is just a translucent overlay that you can use to animate colors or you can delete it if you don't want to animate color. I make it red so I can find it in the designer easier to link my color bindings to it. I usually add a style property and bind to a style class instead of a straight color binding.
I sometimes adjust blend mode to match the general color of other symbols.
I'll try attaching them to the post and hopefully they come through. They are not showing up for me in the forum post window which is abnormal.
large-industrial-blower-with-color-overlay|0x0
blower-with-overlay|0x0Edit: They showed up.
So here's how you use them...
Right click on them in the forum post to download the picture as an SVG. Then you just drag/drop that in your designer and click the option to "embed" This will make a drawing object in Perspective based on the SVG. Then you just find the color overlay and animate it with a binding.
