Perspective Carousel - Script to advance pane
I have a simple carousel with 6 panes and it works fine. I would like to use it to show a sequence of events so I would like to write a script that will cause the carousel to advance to the next pane.
What I was hoping for is to see the animation when advancing to the next pane.
I made a simple button with the following onClick script. It does change the pane, but doesn’t actually show the animation between panes.
	activePane = self.getSibling("Carousel").props.activePane
	paneLegnth = len(self.getSibling("Carousel").props.views)-1
	if(activePane<paneLegnth):
		self.getSibling("Carousel").props.activePane=activePane+1
If I click on the carousel dots or arrows it advances to the next pane and shows the animation.
Is there a script that can be used to advance to the next pane and show the animation??
I would also find this useful, did you ever find a solution?
No. Started using the Perspective View Canvas instead.
