This chart was used in the form of a bar in TIME SERIES CHART.
Is it possible to do an XY chart with three data in one bar vertically stacked like that in the attached file?
Use 3 series on the XY chart (temperature, pressure, test).
Under each Series in the XY Chart set render to 'column' and column.appearance.stacked to True.
All series must be referencing the same yAxes to stack.
Change all yAxis to F2 and they will stack. Create one yAxis for the units that F2, F3, and F4 reference.
