Perspective column container breakpoints
Hi all,
I'm working with a column container and I'd like to have just 1 breakpoint, i.e. the sm one with minWidth=0. I can delete the other breakpoints in the Designer, but after closing/opening the view the other breakpoints are still there and my UI shows not correct - active breakpoints depend correctly on the browser actual width. Is it any way to work with just one breakpoint?
It would be nice also if the column container's number of columns could be configured, not to be forced to fill 12 columns.
UPDATE
For the 12 columns request, I solved via CSS:
#mytbl .responsive-container {
    grid-template-columns: repeat(7, 1fr) !important;
Thanks, regards
Have you tried setting the Medium and Large breakpoints to the same width?
