Trying to follow the tutorial here:
https://www.inductiveuniversity.com/videos/column-container/8.0
When I create a column view and click on the root container, I don’t see an option to change the column size. It’s a simple step to follow and I’ve done it multiple times now with no result. Not sure if this is a versioning issue.
I’m running v8.0.2.
Has anyone else seen this?
Ah, if you’re referring to the count of columns (props.columns), that property was removed in 8.0.1. There is no longer a way to modify the column count.
The property was removed because odd values resulted in undesirable behaviors for some components.
Inductive University is aware that the video is out-of-date, but updating the video is still on their to-do list.
Makes sense.
I was worried that I had a bad install. Apparently my designer doesn’t maximize for some reason. When I click on the maximize button, it just resizes to full screen but doesn’t actually maximize.
I thought that was weird and figured maybe my installation is bad.
Have you noticed the designer maximize issue before?
I have not, but quirks like that are usually environment-specific. Could you provide the specifics of your environment so that I could attempt to replicate the issue? (OS w/ version, Ignition build number) Also, how many monitors are you using? We’ve noticed some odd behaviors in workspaces which uses multiple monitors, especially if the workstation is a laptop which is regularly disconnected and re-connected.
I work with 3 screens.
My laptop is Windows 10 Pro x64./ i7 Processor / 32GB RAM
| Ignition Platform |
8.0.2 (b2019060511) |
| Symbol Factory Module |
6.0.2 (b2019060511) |
| WebDev Module |
4.0.2 (b2019060511) |
| Alarm Notification Module |
5.0.2 (b2019060511) |
| SFC Module |
| OPC-UA Module |
| Enterprise Administration Module |
3.0.2 (b2019060511) |
| SQL Bridge Module |
9.0.2 (b2019060511) |
| DNP3 Driver Module |
| Vision Module |
10.0.2 (b2019060511) |
| OpcCom Module |
| Reporting Module |
| Perspective Module |
1.0.2 (b2019060511) |
| Web Browser Module |
Connected Gateway : http://hosted-on-different-vm:8088
Java Version : Azul Systems, Inc. 11.0.3
JVM Memory (used/max MB) : 208.0 / 1,024.0
Client Time Zone : America/Los_Angeles [GMT-8:00]
Gateway Time Zone : America/Los_Angeles [GMT-8:00]
Thanks. I’ll attempt to replicate the issue when I can find some time today.
