Perspective Component Error
I’m running Ignition-SDK-Example perspective-component.Besides,I make my own Chart in the same project.Example demo work correctly but my chart just show words ‘Component Errors’.
Then i wonder know what errors happened.So where can i read the console or logs?
Thanks.
I am facing the same issue now …is it resolved for you?
these are js errors caused by your js code probably. in run mode you can hover (or click) the (i)
or check the console. (in chrome inspector)
Thanks for your reply…the issue came from the checkbox column …it remains editable on the selected column and ticked even after clicking on the button so made an editable of that column disable and then enable in button script then the component error not thrown… :slight_smile: :slight_smile: :slight_smile:
