Perspective Component - Perspective Workstation
Hello,
I have developed a Perspective component that works very well with web browsers.
However, when I try to use the Perspective Workstation, it cannot find the component in its ComponentRegistry.
Is there something that needs to be specified or done to make my component compatible with Perspective Workstation?
INFO  [WorkstationLauncher           ] [2024/08/09 09:39:37]: Set initial logging level to INFO
INFO  [GatewayConnect                ] [2024/08/09 09:39:44]: Attempting to connect to gateway http://localhost:8088...
ERROR [Console                       ] [2024/08/09 09:39:51]: onerrorLogger: {"stack":"SyntaxError: Unexpected token '&&='","message":"Unexpected token '&&='","name":"SyntaxError","logData":{"msg":"Uncaught Exception","errorMsg":"Uncaught SyntaxError: Unexpected token '&&='","url":"http://localhost:8088/res/engine3d/E3DComponents.js?no_cache=1723189190670","line number":79766,"column":20}}
ERROR [Console                       ] [2024/08/09 09:39:51]: Uncaught SyntaxError: Unexpected token '&&='
WARN  [Console                       ] [2024/08/09 09:39:51]: PerspectiveClient.ComponentRegistry.NotFound: Error rendering component.  ComponentRegistry does not have an entry for type 'aio.display.engine3d'
Is JavaScript interpreted differently?
This operator became available in Chrome 85.
Workstation might be using an older version of Chromium.
