Perspective date time input - Can you add an option for current datetime?
I have a Perspective date time input with an onStartup script to give it the current datetime.
Would also like to have it zero the seconds if it can.
def runAction(self):
	from datetime import date
	self.props.value = system.date.now()
But manly I'd like the option to simply set it to the current datetime after the operator has set it to a few different dates.
Something like the "Today" option on the old MS Office DateTime Picker.
There is no need to import datetime
If you want a date to have zero seconds that can be accomplished.
self.props.value = system.date.setTime(system.date.now(),hour,minutes,seconds)
The other is not a terrible Idea, you should create an Ideas post.
This seems to work:
	date = system.date.now()
	self.props.value = system.date.setTime(system.date.now(),system.date.getHour24(date),system.date.getMinute(date),0)
An expression binding of now(0) will run once on startup so you can use this in any of the date/time inputs to set the date. e.g.,
midnight(now(0))
For your application you want something like,
setTime(
	now(0),
	getHour24(now(0)),
	getMinute(now(0)),
	0
https://docs.inductiveautomation.com/display/DOC81/Date+and+Time
