Perspective Designer shows error if CSS variables used as colors
I thought it would be a good idea to utilize some of the CSS variables to set some of my background colors. I wanted my project to remain consistent with the selected theme.
I'm using nighlty 8.0.14 (b2020051802) which includes the theme update.
For example, I've set a background colors in a menu tree to a variable value:
backgroundColor : var(--neutral-30)
which works great but the designer doesn't like it
I think it would be great if the designer recognized the variables as a valid format.
You can also change the property name to background and the error will go away, however I do agree that you should be able to use that in backgroundColor!
It’s just --variable. No need to wrap it in var().
What a genius idea! Its almost like you made the thing :thinking:
Just tested it in the same nightly and it worked great, not sure where I also had the idea that var() was needed?
Even Better! Thank you
No worries. I can tell you that I’ve made the same mistake before as well.
