Hello,
My designer keeps having the main editing window dislocate from the rest of the designer, and I am unable to grab it and move it back, and it covers up the Properties editor so I cannot open the properties. I cannot select different windows either.
Also it seemed to cause my designer to believe the Gateway had changed resources than mine when I when I go to save, and I know that is not the case because I am the only accessing this gateway.
Reset Panels does not help
This does get solved when I close and reopen my client though, it is just annoying when it happens because I have to save and close everything out and then reopen it all.
Thanks if anyone knows a solution!
