Hi all,
I've been working on a small module for Ignition 8.3 and wanted to share it, along with a few things I learned building it.
The problem
Most of us have written something like this:
self.parent.getChild("FlexContainer").getChild("FlexContainer").getChild("SaveButton").props.text
During development, layouts change constantly. Rename a container or move the button into a new flex and every script that walked that path needs rewiring. The lines are long, hard to read, and tied to the exact structure of the view.
The idea: borrow from the web
In the browser you'd write document.getElementById("saveButton"). Perspective already has meta.domId, so the first version added exactly that:
btn = system.dom.getElementById("saveButton")
btn.props.text = "Saved"
It returns the same kind of object as self, or None if nothing matches. It reads the current page and view from the script's thread, the same way the built-in system.perspective functions do, so you don't pass self. By default it only searches the view the script runs in. Searching docks, popups and embedded views takes a separate call, system.dom.getPageElementById, so leaving the view is always deliberate.
What I found when I measured it
Perspective only lets a component's property tree be read on its execution queue. Script threads aren't on that queue, so every meta.domId check is a hand-off to the queue plus a wait, about 35–45 µs per component. A component's name and type are plain fields held in memory, so checking them is far cheaper.
Test views of 106–129 components, Ignition 8.3.9 in Docker, timed with System.nanoTime(), ranges over several runs. Rows marked * include one .props.text read:
| Lookup | Time |
Native getChild chain, 7 levels * |
56–215 µs |
getElementByName * |
67–93 µs |
getElementById, early hit * |
0.3–0.6 ms |
getElementById, deep hit * |
1.8–2.5 ms |
getElementById, miss |
3.2–4.3 ms |
That's imperceptible for a button click, but it adds up in scripts that run often (although you shouldn't be getting the reference fresh every time, if in a loop). So the module grew:
getElementByName/getElementsByNamematchmeta.namewith no queue hops. Names survive moving a component but not renaming it;domIdsurvives both.querySelector/querySelectorAllsupport a small CSS-like syntax:button,#id,.class,[name="Save"], compounds likebutton#save, and comma unions. Cheap checks (type, name) run first, sobutton#saveonly readsdomIdon buttons.- Multi-match versions return Python lists, and every function has a
getPage*version for searching the whole page.
The surprise: sometimes faster than native
On the benchmark suite view, getElementByName("DeepTarget") searched all 106 components and still matched or beat the hand-written chain to the same button in every run: 67–93 µs against 85–215 µs. That's the opposite of what I expected from a search versus a direct path.
The cost of a getChild chain isn't finding the child. In Java, getChild is a quick match on names held in memory. The cost is crossing between Jython and Java at every step. Each .parent or .getChild(...) in the script:
- looks the attribute up on Perspective's script wrapper (which checks for custom methods first, then falls back to Jython's reflection),
- calls into Java, and
- wraps the returned component in a new script wrapper.
self.parent.parent.getChild("Body").getChild("SecDeep")... is about ten of those round trips. getElementByName is one: a single call into Java, an in-memory walk over the tree with plain string compares, and one wrapper for the result.
It isn't a guaranteed win. On the 129-component view the native chain ran in 56–71 µs, so treat name lookups as "about the same cost as the chain, without the brittleness" rather than an optimisation. And none of this applies to domId lookups, which pay a queue hop for every component checked.
What I learned
- Measure, and measure more than once. My results varied by up to ±50% between runs, so a single number would have been misleading.
- Property access costs too. Every
.props.xread or write, onselfincluded, goes through that same queue (about 45 µs measured). Look a component up once per script and keep the reference, but don't expect the reads after that to be free. - Count the crossings, not just the work. A search done entirely in Java can beat a short path that hops between Jython and Java at every step.
- Fail loudly. An early version of the selector parser silently ignored attributes it didn't understand, so
[enabled=true]matched every component in the view. Unsupported syntax now raises an error. except Exception:doesn't catch Java exceptions in Jython. Use a bareexcept:or catch the specific Java class.- Make scope explicit. A script should never reach into another view by accident.
Try it:
Write up, live demo, source and a signed .modl that also runs (MIT, Ignition 8.3): http://portfolio.mooresedge.co.uk/ign-dom
It's early, so I'd really welcome feedback. In particular: is there a supported API for this that I've missed, and what other lookups would you find useful?
