Perspective Drawing - Union of multiple objects
Hello,
Is there currently a way to union or merge multiple objects using the new Perspective drawing tools?
I have been experimenting with masking and clipping, but I have not found a reliable way to remove the overlapping stroke between two adjacent shapes. In Vision, I can combine the objects so they appear as a single shape without an internal border.
Is there an equivalent feature or recommended workaround in Perspective, or is object unioning not currently supported?
Thanks!
Hi Pnash,
For myself, the way I've worked around this is by creating the drawing with the overlapping strokes.
Once I am happy with the overall shape I apply it in the view.
After that, I right click the drawing in view and press the "flatten" action.
Then you get a single shape, from there you can edit the drawing and add an outline stoke if you like.
I hope this helps!
