Perspective Dropdown Component - Overlap main view from side menu
Hello all!
Have you guys ever used a dropdown in a side menu? If so, were you successful in overlapping the main view? We are having issues to see a rather long string on a dropdown, so I wanted to see if someone knew how to fix that...
I've tried out a bit of styling to see if something would make it work, but no dice so far.
Try adding in,
props.dropdownOptionStyle.whiteSpace : pre-wrap
Dropdown label wrap
That will, at least, wrap the labels when dropped down. There should be a way of wrapping the selected item too. Hmmm.
Yeah, at least we can read what's there. Thank you!
Still, can anyone from IA tell us if it's this has another fix either hidden or planned for a future release? It would be a nicer solution rather than just breaking the line...
You may try using overlow hidden CSS property
CSS Overflow (w3schools.com)
That would hide part of the text. The OP wants to show it!
ah ok, misunderstood.
your fix seem right one.
It's not an IA issue. It's the way of the web.
Try adding this to your advanced stylesheet1. Note that it will apply to all dropdowns in your project.
 .iaDropdownCommon .iaDropdownCommon_value {
    overflow: hidden;
    text-overflow: ellipsis;
    white-space: wrap;
    padding: 2px 4px;
This will override the default theme settings.
1 Project Browser → Perspective → Styles → right-click → Advanced Stylesheet.
Sadly that didn't work, so I've decided to mess around in the Chrome DevTools to find out what could be done. Here is what I found out:
  1. The dropdown options are shown in a modal.
    1.1. The classes of that modal are .ia_componentModal .component-modal-large-viewport .component-modal-below hide-arrow .iaDropdownCommon_options_modal .ia_dropdown__optionsModal
  2. Inside that modal, there are two <div> depths, with some global CSS rules applied to them.
  3. Further down there is another <div>, classed .iaDropdownCommon_options. This <div> contains the list components, which are <a> components. Using the props.dropdownOptionStyle influences those <a> components, which do not influence their modal view.
I believe there should be another style prop, something like props.dropdownModalStyle for styling that root <div>, as there might be cases where you need to override that styling in a single component.
For now, I'll keep using the first solution given, as I need to deliver an MVP soon enough.
