You should modify the option for each entry to include your path attribute. You should then add a change script to Dropdown.props.value with the following code:
if currentValue and currentValue.value.path: # the second bit will skip over your "Select Cam" option.
system.perspective.openPopup("SomeUniqueID", currentValue.value.path)
Continuing the discussion from Perspective Dropdown list with Popup windows:
Thank you for your answer.So I added the path from the view I want to open as a PopUp window and I added the change script as well ,but I cannot understand how to create the SomeUniqueID value from the script below and how it is connected with the view :
system.perspective.openPopup(“SomeUniqueID”, currentValue.value.path)
The ID isnot connected to the view
Its for the popup, only one popup with the same id can be open, the id is mainly used to close the popup again.
