I have a number of dropdown (inbuilt ones) that the onblur event is not triggering the collapsing of previous dropdowns.
If I click onto the background it closes them. Ignition 8.1.51
What else are you doing with the drop-downs?
I have never needed to use the onBlur event (Ignition 7.x through 8.3.x)
I am not using the onblur either, other then to put a message in them to make sure the event is being fired.
They are just normal drop downs populated by a named query.
Can you post a nicely cropped view of the Project Browser section showing the relative positions of the Assets dropdowns and their holding container(s)?
Is onBlur the only script running on those drop-downs?
Are there more bindings than the NamedQuery on the options?
What are the other settings? multiSelect, showClearIcon, allowCustomOptions, META?
Grasping at straws with you... maybe disable the onActionPerformed event and see if the drop-down collapses when an option is selected.
I tried this with a few dropdowns that were completely stock and i did see all of them staying expanded when you click from one drop down to the other but the onblur event did fire. I actually noticed this behavior some time ago but just lived with it, though it may be a bug.
If the latter dropdowns show selections that depend on the earlier dropdowns, consider keeping them disabled until their prereqs are met.
They do not, this was just a test to see whether or not they stay expanded if you click from one to another. In production nobody besides me even noticed it so i just dismissed it.
Yes, this is the issue.
The onblur works etc, just the design is not pleasing. Specially with dropdowns also in my table so they can stay open until I click off.
This is the same in all browsers I tried. Edge, Firefox, Chrome.
So sounds like a little known display bug. I had tried to get around this by closing the dropdown options on blur, but that doesn't work either.
I'll just have to hope its fixed in future versions and move on.
I finally realized that my drop-downs do it too but no one ever noticed it. In most cases:
