Perspective Dropdown property to show all text
Good morning,
I have a Perspective drop down component with entry values that are wider than the drop down component itself. Hence, you cannot read the full entry value in all instances. Is there a way to show the full entry value clearly? Or is this the wrong component for my problem?
You could add this in the advanced stylesheet
.iaDropdownCommon_options_modal{
width: auto !important
This works well for versions after 8.1.21 when the advanced stylesheet was introduced. Thanks.
Hi guys, is there a way that this would affect only one dropdown ? I only want this style for certain dropdown of my project.
CSS
The CSS addition provided by victordcq seems to work correctly for me in Designer on Ver. 8.1.41.
What problem are you having?
Hi there, its working on my end also but it applies on all dropdown, but how can I apply this style on a specific dropdown only ?
You can probably apply a style class to dropdownOptionStyle and use this to target a specific popup's options.
You might be able to directly apply the auto with to this class, or use ::has to find option modal containers that have that class.
I will try that, Thanks
I was able to make it work using ::has method
.psc-DropdownCustomWidth {
	padding: 1px;
.iaDropdownCommon_options_modal:has(.psc-DropdownCustomWidth){
thanks for this useful suggestion !
