So I’m testing some stuff for an upcoming project and I’m having issues using an embedded view. I setup a basic view off a UDT drop. The UDT populates all the data properly and I set all the parameters to bi-directional. When I go to utilize the drop down list to change a value, it changes then it reverts back to the value within a second or two. If I do the same thing in Vision, it works properly and if I just use the same settings straight on the view with the normal tag it works fine.I tried using an onSelect script and that doesn’t help either.
I’m using version 8.0.7 currently.
