Perspective - Equipment Schedule header configuration
I can't find enough information on the user manual on how to configure the headers on the Equipment Schedule component, if at all possible, other than styles.
This is the image shown on the manual for example.
Which is already slightly different from what I currently get on 8.1.42
For example, the dates on the manual are just numbers, which is cleaner, and that was my first goal. My second desired configuration, if possible, would be to display primary/secondary/tertiary headers in different scales and/or different formats. The current scale is out of proportion for certain applications like mine, where it's more oriented to a weekly, monthly, and quarterly schedule. Currently it jumps from days to months, and it would be nice to have more granularity in between.
For example, here are some suggestions:
Days: primary = month-year // secondary = fiscal week // tertiary = day of month.
Weeks (new): primary = quarter-year // secondary = month // tertiary = fiscal week
Months: primary = year // secondary = quarter // tertiary = month
The application is for internal use in the company for resource allocation. I understand that this component might have been originally designed for a different type of application, but it's close enough that I can make it work with just a few adjustments. I'm adding some workarounds to accommodate different styles for weekends, holidays, etc. So, please consider my perspective (pun intended) and the above stated as a potential use for improvements on the component.
I'm pretty close to getting it to where it does everything that I need, but please let me know if there's a better component for this type of application such as on ignition exchange.
I can only help you with your first desire, just change your session props > locale to "es-EN".
I see your intention, but I didn't mean to switch to Spanish. Or did you mean a different locale?
Hello,
I am having the same problem, I would like to write the day as number and day of the week to help with the weekend and scheduling but i am not able using a new key named format… anyone has an idea ?
