Ok after a a couple of days of messing with this I am coming to the experts for some advice.
This is what I am trying to setup
I have a diodeoncolor in a 14 segment LED “TAG2” that I want to change change color based on the tag value of a different tag let’s call it “TAG1”
so for example:
if TAG1 = 1 and TAG2 > 80 then diodeoncolor will be red or #FF0000
if TAG1 = 2 and TAG2 < 80 then diodeoncolor will be green or #00FF00
I have been messing around with expression bindings and I know the syntax is not like python but I can’t get anything but errors. Am I on the right path with trying to use an expression binding or is there a better way?
What do you want to happen if the value of TAG2 = 80?
What do you want to happen if TAG1 = 1 and TAG2 < 80?
What do you want to happen if TAG1 = 2 and TAG2 > 80?
What do you want to happen if TAG1 is not 1 or 2?
Why anyone would want to make a difficult to read 1970s looking HMI when Ignition gives the possibility of using clear Truetype character display is beyond me but anyway ...
Create an expression binding on props.diodeOnColor.
@Tom.roberts
I'm not quite sure what it is you're trying to do, could you clarify your inputs and expected output ?
Are you setting up a tag ? A display component in a view ? What's the possible range on your variables ?
