Hi, I have ignition installed but unable to design any perspective views on designer.
Can anyone help, I’m guessing its my firewall or something blocking a certain dependency.
Cheers.
16:36:37.284 [Designer-Startup] INFO designer.main -- Downloading... [+0]
16:36:37.428 [Designer-Startup] INFO designer.main -- Cleanup... [+144]
16:36:37.436 [Designer-Startup] INFO designer.main -- Initializing UI... [+152]
16:36:37.516 [DesignerExecEngine-1] INFO tags.subscriptions -- Changing connected quality to 'Good'
16:36:42.331 [Designer-Startup] INFO designer.main -- Starting module: Vision [+5047]
16:36:46.666 [Designer-Startup] INFO designer.main -- Starting module: Perspective [+9382]
16:36:48.476 [Designer-Startup] INFO Perspective.Designer -- Starting up Perspective module. Mode: Activated
16:36:50.250 [Designer-Startup] ERROR Perspective.WorkspaceRootConfig -- Unable to set up session props adapter
com.teamdev.jxbrowser.navigation.NavigationException: Failed to load resource: ABORTED
at com.teamdev.jxbrowser.navigation.internal.NavigationImpl.lambda$loadUrlAndWait$0(NavigationImpl.java:109)
at java.base/java.util.Optional.ifPresent(Unknown Source)
at com.teamdev.jxbrowser.navigation.internal.NavigationImpl.loadUrlAndWait(NavigationImpl.java:108)
at com.teamdev.jxbrowser.navigation.internal.NavigationImpl.loadUrlAndWait(NavigationImpl.java:95)
at com.teamdev.jxbrowser.navigation.internal.NavigationImpl.loadUrlAndWait(NavigationImpl.java:87)
at com.teamdev.jxbrowser.browser.internal.BrowserImpl.initializeMainFrame(BrowserImpl.java:434)
at com.teamdev.jxbrowser.profile.internal.ProfileImpl.newBrowser(ProfileImpl.java:156)
at com.teamdev.jxbrowser.engine.internal.EngineImpl.newBrowser(EngineImpl.java:451)
at com.inductiveautomation.perspective.designer.workspace.pageconfig.SessionPropsAdapter.<init>(SessionPropsAdapter.java:81)
at com.inductiveautomation.perspective.designer.workspace.pageconfig.WorkspaceRootConfig.init(WorkspaceRootConfig.java:40)
at com.inductiveautomation.perspective.designer.workspace.ViewWorkspace.<init>(ViewWorkspace.java:198)
at com.inductiveautomation.perspective.designer.DesignerHook.lambda$startup$6(DesignerHook.java:256)
at com.inductiveautomation.perspective.designer.DesignerHook.startup(DesignerHook.java:240)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$LoadedModule.startup(IgnitionDesigner.java:2004)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.startupModule(IgnitionDesigner.java:1200)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.loadProject(IgnitionDesigner.java:1003)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$StartupProjectDialogHandler.lambda$new$2(IgnitionDesigner.java:2048)
16:36:50.452 [Designer-Startup] ERROR designer.main -- Error starting up module Perspective
at com.inductiveautomation.perspective.designer.drawingeditor.EditorBrowserPanel.<init>(EditorBrowserPanel.java:34)
at com.inductiveautomation.perspective.designer.drawingeditor.DrawingEditorFrame.<init>(DrawingEditorFrame.java:115)
at com.inductiveautomation.perspective.designer.drawingeditor.DrawingEditorFrame$DrawingEditorFrameManager.startup(DrawingEditorFrame.java:505)
at com.inductiveautomation.perspective.designer.workspace.ViewWorkspace.<init>(ViewWorkspace.java:219)
16:36:50.545 [Designer-Startup] INFO designer.main -- Starting module: SFC [+13261]
16:36:51.407 [Designer-Startup] INFO designer.main -- Starting module: Event Streams [+14123]
16:36:51.467 [Designer-Startup] INFO designer.main -- Starting module: OpcCom [+14183]
16:36:51.468 [Designer-Startup] INFO designer.main -- Starting module: Reporting [+14184]
16:36:51.517 [Designer-Startup] INFO reporting.Designer -- Starting up Reporting Module. Mode: Trial
16:36:51.860 [Designer-Startup] INFO designer.main -- Starting module: Symbol Factory [+14576]
16:36:51.864 [Designer-Startup] INFO designer.main -- Starting module: Alarm Notification [+14580]
16:36:51.987 [Designer-Startup] INFO designer.main -- Starting module: OPC-UA [+14703]
16:36:51.987 [Designer-Startup] INFO designer.main -- Starting module: Enterprise Administration [+14703]
16:36:52.004 [Designer-Startup] INFO designer.main -- Starting module: Legacy DNP3 Driver [+14720]
16:36:52.004 [Designer-Startup] INFO designer.main -- Starting module: Historian Core [+14720]
16:36:52.004 [Designer-Startup] INFO designer.main -- Starting module: SQL Bridge [+14720]
16:36:52.225 [Designer-Startup] INFO designer.main -- Initializing Scripting... [+14941]
16:36:52.311 [Designer-Startup] INFO designer.main -- Initializing UI... [+15027]
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException: Cannot invoke "com.inductiveautomation.perspective.designer.DesignerHook.getNavNode()" because the return value of "com.inductiveautomation.perspective.designer.DesignerHook.get(com.inductiveautomation.ignition.designer.model.DesignerContext)" is null
at com.inductiveautomation.perspective.designer.workspace.ViewWorkspace.getNavTreeNodeParent(ViewWorkspace.java:370)
at com.inductiveautomation.ignition.designer.tabbedworkspace.TabbedResourceWorkspace.registerNavTreeNode(TabbedResourceWorkspace.java:214)
at com.inductiveautomation.ignition.designer.tabbedworkspace.TabbedResourceWorkspace.lambda$new$0(TabbedResourceWorkspace.java:131)
at java.base/java.security.AccessController.doPrivileged(Unknown Source)
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException: Cannot invoke "com.inductiveautomation.perspective.designer.workspace.ViewWorkspace.setSelectedIndex(int)" because the return value of "java.util.function.Supplier.get()" is null
at com.inductiveautomation.perspective.designer.PerspectiveNavNode.onSelected(PerspectiveNavNode.java:33)
at com.inductiveautomation.ignition.designer.navtree.model.AbstractNavTreeNode.dispatchSelectionEvent(AbstractNavTreeNode.java:847)
at com.inductiveautomation.ignition.designer.navtree.NavTreePanel$SelectionListener.valueChanged(NavTreePanel.java:544)
at java.desktop/javax.swing.JTree.fireValueChanged(Unknown Source)
at java.desktop/javax.swing.JTree$TreeSelectionRedirector.valueChanged(Unknown Source)
at java.desktop/javax.swing.tree.DefaultTreeSelectionModel.fireValueChanged(Unknown Source)
at java.desktop/javax.swing.tree.DefaultTreeSelectionModel.notifyPathChange(Unknown Source)
at java.desktop/javax.swing.tree.DefaultTreeSelectionModel.setSelectionPaths(Unknown Source)
at java.desktop/javax.swing.tree.DefaultTreeSelectionModel.setSelectionPath(Unknown Source)
at java.desktop/javax.swing.JTree.setSelectionPath(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicTreeUI.selectPathForEvent(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicTreeUI$Handler.handleSelection(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicTreeUI$Handler.mousePressedDND(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicTreeUI$Handler.mousePressed(Unknown Source)
at java.desktop/java.awt.AWTEventMulticaster.mousePressed(Unknown Source)
at com.jidesoft.docking.DockingUtils.a(Unknown Source)
at com.jidesoft.docking.DefaultDockingManager.handleEvent(Unknown Source)
at com.jidesoft.docking.DefaultDockingManager$a3.eventDispatched(Unknown Source)
at java.desktop/java.awt.Toolkit$SelectiveAWTEventListener.eventDispatched(Unknown Source)
at java.desktop/java.awt.Toolkit$ToolkitEventMulticaster.eventDispatched(Unknown Source)
at java.desktop/java.awt.Toolkit.notifyAWTEventListeners(Unknown Source)
at java.desktop/java.awt.KeyboardFocusManager.redispatchEvent(Unknown Source)
at java.desktop/java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(Unknown Source)
at java.desktop/java.awt.DefaultKeyboardFocusManager.dispatchEvent(Unknown Source)
at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
