Perspective File Upload Component - Expected Behavior for multiple file uploads
I would like to confirm what is the expected behavior when using the perspective file upload component to handle multiple files. With the scripts below it seems that only one file every ends up in the holding variable even if I have drug multiple files in to upload.
Do I need to be appending to the data holder when handling more than one file?
The event script on the component file received event
filename = event.file.name
filedata = event.file.getBytes()
self.view.custom.fileName = filename
self.view.custom.filedata = filedata
The files are temporarily held in a view custom property
Thanks,
Nick
You are setting the holding variables to filename / filedata. Make them an array and then append to them.
@jpark thanks for the quick reply.
By changing the destination parameter type to array it behaves as expected:
Thanks,
Nick
@jpark with the additional qualifier that if array types have been set, the clear action should be like below, not “None” otherwise an error happens when trying to append the first record to a “None” type:
self.custom.fileName = []
self.custom.filedata = []
Thanks again,
Nick
Hello, I have exactly the same code, but when I want to download several files, only one file appears in the filename variable: ignition 8.1.48
filename is an Array
Manu
This thread is about upload. Start a new thread (and delete the post above).
Welcome to the forum!
