Perspective: Gantt Charts with labels
Hi all,
i'd like to add some text in a gantt chart as in the following example:
Any suggestion?
Thanks in advance, regards
Hello pgmo,
It doesn't look like this custom configuration of the XY chart has a way for us to include labels directly on the objects.
As a workaround, we can utilize the tool tip functionality to include some form of label that is viewable when selecting the specified time frame. Under the example objects, we can create a new property which can then be referenced under the tooltip text property.
I would also suggest submitting this as a feature request by visiting the link below.
Hi @Patrick_Chanthilack , thanks for your reply. I've already done as you suggested, that's a good workaround. I'll submit a suggestion to Ignition Features and Ideas.
Regards
Adding the text on the bar of gantt chart(not on the tooltip) is that not possible ?
Looks like this can be done with series[x].line.appearance.bullets[0].render:label
