Perspective gateway backup
HI,
To have 1 perspective gateway backup you need 2 licenses?
Cheers
The question is very vague. Is it scheduled backup? Why do you think you would need 2 licenses? What do you mean by Perspective gateway backup? A gateway backup would have all resouces in the gateway not just perspective. You might need to explain more about your setup.
I mean, if main server fall, can use same license in another server to keep the service runing?
Do you mean to setup failover gateway? Found this.Perspective (Main Gateway and Failover) - #2 by pturmel
Great, thanks, that´s what I wanted to know, can´t be more concise than that.
I guess can also use the same license and redirect the project to the working gateway
Not really sure how that can work. I found this as well. Redundant Licensing | Ignition User Manual
