In the Perspective properties, there is an outerAxis and innerAxis property. There is a needle property underneath each one, with their own respective color properties. You can change them to whatever you like.
Thanks. I wasn’t very clear. The outer needle (the black one) is covered by the gray inner range…I’d think the needle would be “on top” and not be partially covered by the inner range color…is it supposed to be covered or did I miss a setting?
