Hi
We are working on a perspective based project. Wanted to know how to create a grouped bar chart like this:
We tried manipulating the X-Y chart component, but ended up with this result:
All the bars should be vertical, and Just one Y-axis should be displayed.
Did you find a solution to this problem?
I have send a mail to IA support and the response that I got was:
You can “group” the bars together in the bar chart by adding a blank series either side of the series that actually show data, and then setting the values to 0 and setting hiddenInLegend to true so they do not show up in the legend. You only have to set the values in one set of your data sources, as shown below:
Once you add these blank values to your list of series, you should get something that looks like this:
It’s not exactly like in the example you sent me, but it’s fairly close. If you want to remove the white space between the bars in each group, just change
width under the
appearance section for each series.
Hi @indenkleefj, how to show the values on top of the chart, for all bars
like below image
I need this requirement for my project
Thanks.
Anyone know how to do this in Ignition Perspective XY Chart.
Thanks in Advance.
There isn't a nice way to do it, but the following does work. It requires adding an additional series for each existing series - new series rendered as line types with labels instead of bullets.
