[Perspective] HTTP Error 503 Service Unavailable
Hello. Since we've updated to Ignition 8.1.43 we've been encountering an annoying issue.
Every morning, when we start up our system, Chrome loads up with a Error 503 Service Unavailable message. The browser automatically opens after around 5 minutes pointing to the login page of our project through a Windows Scheduled Task.
We've never encountered this behaviour beforehand; moreover rebooting the system apparently resolves the issue.
The gateway logs show a bunch of warning like this one at the start up of the system:
Invalid configuration type hierarchy for node '000800c5-eb18-4844-9a9b-0257f45e6af6.42e12ad3-2721-421d-af86-c14dbd5909ca'. Parent entity '000800c5-eb18-4844-9a9b-0257f45e6af6' was not found, or not loaded in the correct order.
The node UUID changes for every entry.
Anyone? We've noticed that's possible dependant on the last Chrome versions, more than on Ignition.
If they are warnings they are probably not causing any major problems. If they're returning after restarting you should get into contact with support they may need to look at the internal DB. The error could indicate the IdB has some inconsistencies with older or recently edited tags.
I've been in contact with support and I've been asked to try Perspective Workstation in place of Chrome Kiosk mode: we're going to try that solution.
