Hello everyone.
I've been trying recently to create a view with a multi-state button with icons instead of text, as shown here:
But I can't seem to find any way of inserting an icon, as is possible with the 'image' property of a regular button. Is there perhaps a way around this or another option\method for multi-state buttons?
Try using background images: states.0.selectedStyle.backgroundImage : url("/system/images/path-to-image.svg")
and do the same for states.0.unselectedStyle. ...
Repeat for each button option.
Use Tools | Image Management to upload the icons.
If I was to use your application I'd surely appreciate tooltips on your icons. I have no idea what they might mean. The problem is that there is only one tooltip for the whole multistate.
Thank you for your advice. FYI now there is tooltip for each state in the multistate button.
Do you think there may be any other method other than background-image? I need to put an icon next to the text. I think it can also be done with background-image, but I was just hoping for simpler solution.
Another way to do it is to convert the SVG to CSS (assuming your icon is an SVG) and embed it in a style in the advanced style sheet and using a map transform to select which style to apply.
If you haven't used advanced style sheet before; it's important to understand that your style needs to have a 'psc-' prefix in the style sheet and you don't include that part when you're using the style.
So if your style is defined as 'psc-test' in the advanced style sheet you would add 'test' to the "classes" property in perspective.
There's a real useful website that converts SVGs to embedded CSS. You'll also want to look into various CSS properties that dictate how an SVG renders in your style. There's a ton of interesting options.
