Perspective - Image - Brightness/Contrast
8.1.12
Is there a way to be able to adjust brightness and contrast of an image in perspective ?
yes with the style filter.
I’ve never tried it but you could use an overlay and vary the transparency. Try a label the same size as the image and set the background fill to black or white and adjust the transparency to suit. Start with 50%.
Better again, use the theme styles and use, for example, --neutral-30 which will follow the theme settings. See https://docs.inductiveautomation.com/display/DOC81/Perspective+Built-In+Themes for more. Create a slider or a dropdown in your application and bind it to session.props.theme. It adds coolness to your application with very little trouble - provided you don’t mess up by applying direct formatting to your components. Use the styles.
@Transistor
While thats possible, it’s a lot more work and less performant then adding in a filter style
you can use float where 1 = 100% or just use %
examples:
filter: brightness(0.4);
filter: contrast(200%);
Cool. I hadn’t explored that.
This is the way to go.
