Perspective - is selected text color setting available to add to style or somewhere in session props
Does anyone know where to find the setting in ignition that controls the color of the selected text on the screen. below is the CSS code that controls it. I am working with a predefined theme from my company and the color they picked is impossible to see on a white background.
*** Works on common browsers ***
selection {
    background-color: #352e7e;
    color: #fff;
There are a couple of different places which allow for setting CSS rules, with the differences depending on the scope or breadth of your desired impact.
To apply this setting to:
  • Every project on the Gateway, create your own custom theme files which inherit from the default Perspective theme files and place this rule within the appropriate file.
  • Just a single project (only available in version 8.1.22 or newer), use the stylesheet.css resource available by right-clicking Styles in the Project Browser within the Perspective context and selecting Enable Advanced Stylesheet.
you need ::selection though
I cannot find where to apply the advanced stylesheet under props. can you help me understand how to get this implemented correctly?
The advanced stylesheet is always applied
its just a common ccs file. you need knowledge of css to be able to define classes and such...
The naming of the class is wrong the prefix is psc- not psc_
and you as always for css you still have to add the class to the component,
This looks like you're trying to set the rule to only apply to certain components which have a Style applied, so that's what my steps will describe. If you want a broader application, the steps will vary.
  1. Create a named style within the Style directory. For now, let's assume you name this Style "Selected". You do not need to apply any setting to this class.
  2. Set Landscape in: TextField.props.style.classes to have a value of "Selected".
  3. In the stylesheet.css resource, supply the following code:
.psc-Selected::selection{
    background-color: #3352e7e;
    color: #fff;
Thanks for the help, the steps you outlined along with your code suggestion helped me to get it working in my project.
