Perspective issue after making the necessary changes in start up script
Hello,
I am currently trying to enable a button when administrator users role are logged in from perspective and disable a button when only regular users are logged in.
I have attached the snapshot of the code!
Can you please help me out with this issue?
2023-07-25
You haven't explained what your issue is.
I'll tell you one thing, though: system.user.getRoles returns a List of roles, so comparing it directly to "Admin" won't work.
Apologies,
I have created two roles with one being "Administrator" and the other being "User"
And there's a spelling error - it is Administrator and not Admin
The problem lies when the button is not enabled or disabled for the respective conditions when I try to login with Admin or User credentials
Where does this script live? Is it a custom method on the root container?
The script is written in the root container on startup
I think the issue is what Kevin had mentioned. You are trying to compare a list to a string. You could check if 'Administrator' is in the list of roles if "Admin" in role:. A simpler approach may be to use an expression binding directly on the enabled property of the button. indexOf('Administrator',{session.props.auth.user.roles})>-1 might work correctly in the expression binding.
The expression binding should be: indexOf({session.props.auth.user.roles}, 'Administrator')>-1. I had switched the order of the parameters.
In expressions, hasRole(role, username, usersource) will also work (the second and third argument are required for Perspective):
You'll need to get username and user source from the session props, here's a more specific example. I just included the other one because of the nice screenshot:
To make it clear, you should never use the startup script to disable graphic components directly (not that you can). You should always use a binding on the component, or, in rare circumstances, a script from another graphical component in the same view.
Consider the situation where you need to add other conditions to the enable button as well. If you use a startup script, you're screwed (so too are you using another component script without thinking, hence why I said that would be rare)
Thank you caleb
It is working now
