Perspective JSON as parameter for script
Hello, I’m using a JSON from a perspective view to build a sort of wizard.
I made some input box binding to some properties of the JSON and everything is ok, then I have two buttons with some scripts and I’d like to understand what’s going on.
Pressing the first button I read the JSON and I pass it as an argument to a script function like this :
 obj = self.view.getChild("root").custom.porta #<-- json from perspective
 func1.Go(obj)
 func2.Go(obj)
func1 : modify state of JSON
func2 : print out JSON obj
I notice that func2 seams to work on a not updated JSON, and if I print the state I can clearly see that the attributes are not being modified from func1.
However, if I check the JSON state from the GUI I can see that the attributes are changed.
If i repeat the process, i can see on the output that the JSON is updated from the last call, so i end up always with one iteration of delay.
Button 1 :
 func1.Go(obj)
 sleep(10)
 func2.Go(obj)
Button 2 :
 system.perspective.print(obj)
Clicking the first button and then the second one, I can see JSON printed out is correctly being modified from func1, however after 10 seconds I got the printed text from func2 JSON printed is not updated.
I noticed some strange behavior when working with arrays too.
Am I missing something or am I not supposed to work in this way?
Adding a note :
A way to reproduce is to create a JSON like this one :
Schermata 2021-10-26 alle 18.07.15
First button Script :
obj = self.view.custom.test
obj['val_1']['index'] +=1
index get incremented by 1.
Second Button :
self.view.custom.test.val_1.index += 1
It work as expected.
Thank you
I’m guessing you’re updating the view param, not the obj you’re passing to your functions.
try
func1.Go(obj)
func2.Go(obj)
and see if it works as intended.
thank you but this was one of the first test i did, Is two days I’m trying to understand what’s going on,
i did a lots of test :slight_smile:
can you show func1 and 2?
objects and arrays work with references, so depending what you do with them, they might (not) update the reference.
I don't really have func1 and func2
I expected them as work like them, but you can see there is something going on on this step
and i think is the same thing that happen when i pass the object to different functions
I've had the same problem.I use this, to get individual objects.
import deepcopy from copy
Thank you, I will try this solution.
deepcopy doesnt really work for me it seems. giving some type errors “com.inductiveautomation.perspective.gateway.script.PropertyTreeScriptWrapper$ObjectWrapper()”
however this works:
	index=obj['val_1']['index']
	index +=1
	index +=1
	index +=1
	index +=1
	index +=1
	obj['val_1']['index'] = index
Here is no error with me.
for text it works, but when there are objects in it
Also i would like to note that you are not using json. You are using objects which just look like json.
Json is just a structure^^
I tried list, tuple, and dictionary, maybe it doesn’t work for some object.
most of the things im trying doesnt work :stuck_out_tongue: maybe just have a thing for trying the impossible xd i always find the edge cases xd
Thank you for the information,
is that a json from perspective being casted in a python dict? or is not json even at the beginning?
There is definitly some json involved. The views get saved as json. But there first is a whole bunch of java in between.
I found a very ugly solution but it’s working so I’m going with this one for the moment.
I start the script by encoding/decoding the JSON(?) from perspective session, this way I know I’m working with a decoupled pyDictionary and passing this object to functions work as expected.
Then at the bottom of the script i assign the pyDictionary back to the perspective object.
porta = system.util.jsonEncode( self.view.getChild("root").custom.porta )
porta = system.util.jsonDecode( porta )
Models.Wizard.ComposeItemsCoordinateFromRules(porta)
Models.Wizard.CalcoloPuntiSaldaturaManiglia(porta)
Models.Wizard.ComposeOmega(porta)
Models.Wizard.CalcoloPuntiSaldaturaDeviatori(porta)
Models.Wizard.CalcoloPuntiSaldaturaCerniere(porta)
Models.Wizard.CalcoloPuntiSaldaturaOmega(porta)
self.view.getChild("root").custom.porta = porta
This code creates a deepcopy (the correct way):
If you put it in a project script it should be easyenough to use
	def sanitize_tree(element):
		    if hasattr(element, '__iter__'):
		        if hasattr(element, 'keys'):
		            return dict((k, sanitize_tree(element[k])) for k in element.keys())
		        else:
		            return list(sanitize_tree(x) for x in element)
		    return element
	obj = sanitize_tree(self.view.custom.test)
	self.view.custom.test = obj
