Hi Guys,
I have a Flex Container with multiple Label components.
Even though I have the Shrink = 1 and Grow = 0, Resizing the container, does not shrink the labels when the container gets too small.
Are you claiming that it doesn’t shrink the Labels, or that it doesn’t shrink the text?
The following results were obtained with a Flex Container with props.direction set to “column”…
Room to spare:
Label_0 has shrunk vertically due to a compressed space:
If you are instead referring to the displayed Label text, then you must modify other settings, as text does not change based on component size. Try looking into Media Queries.
Thanks.
Yes, I am trying to shrink the Text. I will look at Media Queries.
