I want to reduce the size of the black background, is it possible?
However, the size of the number remains the same
I'm not exactly sure what you mean, but can you make the width shorter?
I want to reduce only the yellow circled part.
You can use Label as your Display, it's more flexible.
and looks better, and more in line with HMI standards
Thank you
I think it has a minimum width, but if you have enough digits you can fit it all.
