Perspective Map: Color Issue for added Points
Hello There,
I am working on map where is I have successfully added the different points fetching it from Database. I am going through this Manual Page (Perspective Map - Adding GeoJSON Shapes - Ignition User Manual 8.1 - Ignition Documentation) of adding points for reference. But the issue is my Pointers are not added with "Blue" color. All are in "Black" color.
What is wrong I am doing here?
Attaching SS for reference.
It looks OK to me (but is hard to read). Can you post a section of the resulting JSON for one of the points?
Tip: post formatted code - not pictures of code. We would have to type out your script to test it.
Here is the code.
`  ` `"type"` `: ` `"Feature"` `,`
`  ` `"properties"` `: {},`
`  ` `"geometry"` `: {`
`    ` `"type"` `: ` `"Point"` `,`
`    ` `"coordinates"` `: [`
`      ` `-` `121.16945743560791` `,`
`      ` `38.6632293081453`
`  ` `"marker"` `: {`
`    ` `"icon"` `: {`
`      ` `"color"` `: ` `"blue"` `,`
`      ` `"size"` `: {`
`        ` `"width"` `: ` `100` `,`
`        ` `"height"` `: ` `100`
`      ` `"path"` `: ` `"material/location_on"`
`    ` `"tooltip"` `: {`
`      ` `"content"` `: {`
`        ` `"text"` `: ` `"Some text"`
It appears that you have just copied and pasted the sample code from Perspective Map - Adding GeoJSON Shapes - Ignition User Manual 8.1 - Ignition Documentation into your answer above. We need to see the result of your script.
Please preview the code / JSON to check that it is formatted correctly before hitting reply. (The JSON in your last post is a mess.)
It seems the example isnt working anymore, idk what has changed
instead of using color, you can use style fill though
"style": {
  "fill": "blue"
Thanks victordcq!! it worked!!
Would it be a good idea to set both fill and color in case something gets "fixed" in a later version? I'd ask support for clarification.
