Perspective Map/Transform (Linking Output to a Tag)
Hi All,
Is it possible in Map/Transform to link the “Output” to a Tag? I see if I switch my “Output Type” to “Expression” it does give me the ability to link a tag via the “fx” function that appears… however it doesnt seem to work and throws out an error.
Is it possible to do this?
Thank You
Have you tried the tag expression function?
Hi @jspecht - yes we tried the tag() expression function but for some reason it throws an error? Just wondering if this is maybe a bug or something not intended to work?
Updated with a picture of the error. If anyone sees anything from with our tag() syntax please let me know.
Your output expressions for input values 0, 1, and 2 are not valid expressions (they look empty)
Thanks @jspecht ! That was our issue.
