I'm currently employing a perspective message handler for the component. Within my table, each column utilizes a view-selected row update triggered by clicking the Update button (which is also accessible within each table column).
Incorporate receiving the message from the Update button within the root view for the CellName, and utilize the value of this parameter in the onActionPerformed event for updating the selected row.
Currently, I'm encountering an issue during row updates where updating only the Single column triggers automatic updates for other columns, resulting in either blank values or random data being populated. This occurs inconsistently across different columns.
I don't understand this part, frankly... Can you explain why you have a message handler on the Update button to update the row values instead of on the Table component? Also, what is the purpose of that button, to pull new data from a DB for just that row? Last thing - is the CellName parameter an outgoing parameter on your button view?
If I'm understanding you correctly and you're rendering each column as a view, then when you do event.value in the onEditCellCommit component event, I'm almost certain it will be null (or "").
As a test, add this line to the beginning of your onEditCellCommit script:
